I did the same... until I got a new rear bumper with a swingaway tire carrier and mounts for 5 gallon cans. LOVE the look. But also love the look of my new rear, minus the fact I can barely see out the rear view mirror now. hahaha
Easy. Just put the hardware from the spare holder back in the tailgate.bumping this up. Not looking to add a license plate holder, but trying to get ideas on what to plug the factory holes in. Added a smittybilt bumper and swing out spare tire holder, so...looking to plug the factory spare tire holder holes.
Also be sure to wheel with very, very, understanding and patient companions. Otherwise when you cut a sidewall and they discover you ditched the spare they will leave you out there.Here’s my spare delete. I really did it for departure angle. I carry a valve stem tool and a tire plug kit.
Where is "around here"?Where around here would I get a sidewall tear?
EW too. I lost a sidewall from rocks on the breaks of the Snake. Just in the last four years I've seen two sidewalls ruined on the trail by wood plus two destroyed valve stems. It can definitely happen.Eastern Washington. I’m in Spokane.
Want to run a trail together sometime? I don’t even know the trails you mentioned.EW too. I lost a sidewall from rocks on the breaks of the Snake. Just in the last four years I've seen two sidewalls ruined on the trail by wood plus two destroyed valve stems. It can definitely happen.
Sure. Mostly we end up at Naches but occasionally do Rimrock. I like to finally try Liberty and maybe even find a reason to explore Mack, Owl, Thompson, and Twin Sisters out of Kettle Falls.Want to run a trail together sometime? I don’t even know the trails you mentioned.
I never heard of these places, except Naches and Rimrock. Hopefully I’m done with my TCase tomorrow. Pain. Then we can figure something outSure. Mostly we end up at Naches but occasionally do Rimrock. I like to finally try Liberty and maybe even find a reason to explore Mack, Owl, Thompson, and Twin Sisters out of Kettle Falls.
https://web.archive.org/web/20190719142419/http://nwjeepn.com/WAtrails.htmI never heard of these places, except Naches and Rimrock.
I made a similar statement once..... "I've never had a flat in my life."The thing is that I’ve been through 3 sets of tires and never had a flat, much less a sidewall tear.
I had this happen to me! Because I've seen people run without a spare, and liked the idea of increased rear visibility, I ditched mine once for a trail ride. Part of the way through the ride someone comes over the radio and tells me my right rear tire looks extremely low on air. We stop and I proceed to check it. To my shock, there was a small hole in the sidewall.I made a similar statement once..... "I've never had a flat in my life."
It went downhill from there. I lost 4 tires in a two month span.
Newtons law.... Never brag about your good fortune, it will be your downfall!!!![]()
I plugged them with black plastic push-in style fender retainers.bumping this up. Not looking to add a license plate holder, but trying to get ideas on what to plug the factory holes in. Added a smittybilt bumper and swing out spare tire holder, so...looking to plug the factory spare tire holder holes.
Is that a brake/tail light or brake only? Also do you have a link. Me likey
