That's right. You're no weight conscious sheep.![]()
It's never stopped me from completing a trail.
And? I know it's heavy and I don't care.
good point, i guess theres definetely a lot of factors. Lets say 35's and stock axles (with Super 35)
Damn I hate this threadā¦
Maybe not. But it affects how you get through the trail. If that matters.
What was the neon SRT? That was the 2.4, right? If I had a 4 cylinder jeep, I'd try to find one of those engines to run in it. I'm a BIG believer in turbos...especially factory ones where the fueling is already figured out. I have a 2.0 TSFI Audi and I cannot believe how well that thing pulls. Its crazy...the torque that it makes from such a small displacement is insane. Superchargers are OK...but they suck up something like 80% of the power that the generate just to spin the stupid thing on the accessory drive. Turbo's reclaim "waste" gasses and they are more efficient. Sure, you gotta spool em up, but small turbos can add a few pounds of boost and really increase drivability without a ton of turbo lag. If you're in 4-low, you're probably already spinning enough RPM to keep the turbo spooled.
Also...Shed the weight...especially the sprung weight. Keep some over the rear axle (think spare tire), so the shocks have something to react against but otherwise...make it light and nimble. Aluminum armor, synthetic winch rope, no back seat, etc.
Basically dual transfer cases. It lowers your low range gearing.
Please point me in the direction to learn more about this. Thank you.
I didn't realize that. What about manual vs auto trans weight?Drive-train wise, your biggest weight adders will be moving from a Dana 30/35 combination to Dana 44s front and rear. Combine that with adding a beefier transfer case, like the 241, is why you see a 300 lb difference between the sport and Rubicon models.
For what it's worth, you also have to factor in the flywheel and the weight of the clutch assembly itself.
