I can’t wait for this one…. Do tell
Welcome to the forum!
I haven't dug into it, but the previous design, folks were getting 6 inches up in the front with the motobilt 4 link kit.
It surprises me bc I always had the impression that Rob Park (Bender) really knew his shit when it came to design and fab work.
It may be a compromise between trying to sell a product that’s a swiss army knife and sell something that is geared towards the weekend pro rock crawler.
If I had to guess, anyone building a Jeep to crawl with the best of them, with all the perfect numbers is building something home brew and isn't shopping for bolt in/weld in parts.
I appreciate the amount of discussion here. learning a few thingsThe Savvy mid arm has more VS and less hang below the frame because it requires a body lift. The Savvy skid hangs down about 1.75" at it's lowest point.
I’d love to hear more about this and your assumptions![]()
The Savvy mid arm is so ideal for a TJ/LJ, but are you changing anything like VS, antisquat, etc by lengthening wheelbase on a TJ with a Savvy mid-arm?
The reason I'm asking is to ask are you limited to a certain wheelbase using the Savvy mid arm?
Typical bad geometry with a more work than a bolt on long arm kit requires.
How about that for a start?![]()
I can’t wait to hear about how this geometry is “bad”. PLEASE enlighten me!
That's interesting that you observed that and noticed the MB linked TJ crawled right up some obstacles that others could not make.
Pagrey that you?
Could be. He can't keep track of himself the same way.
Negative, this is Rob from Motobilt.
The Savvy mid arm, in and of itself does not change the wheelbase. That is it's own separate project.
Looks like he took back the big reveal.
I’d get the popcorn from here on out![]()
So with the Savvy Mid-Arm out of the box, as is, the Jeep is built around a specific tire size, which is a 35 inch tire, correct? Any deviation from this is a foul is what I'm taking from your reply.
