I was contemplating that trail over spring break. I’d be tempted to give it a go next time we’re down there.
Ordered all the things for the electrical. Fuse box, wires, fuses, relays, switches of all types. I've never done a full vehicle wiring project before, but I figure the GPW is a good place to start.
Since there are no pictures of ordering stuff...
Glamour Shot.
This is a really cool project. Keep it up
wow, insta and life have long outpaced this thread.
Lets catch up.
And you think you are going to put that... where?
I purchased to Tube Bender... we are onto the next level fabrication now... it turned out great. In the fenders, even kept the flip up feature of the headlights.
With the hood and fenders on. The shock hoop will be invisible. The coil over will be the only thing to see, and most people wont see it. This is going to be a very very capable and fun rig, but LOOK like a stock war jeep. Just the way I want it.
Every time I see one of these, I want to build one. The the body lines are absolutely beautiful. Plus, that tire wheel combination are perfect!![]()
I’m going to have to go back and read your whole thread. I just picked up a CJ-2A with a rough body and an M38A1 chassis with a clean Hotchkiss M-201 tub + GPW front clip. I’m going to be combining the 2A chassis with the military body. Great work so far!
Everything was close, so I had to trim, and adjust, but the front suspension is done. I have full steering lock to lock at all angles of articulation. Coil overs are mounted, reservoirs have a home and jeep is sitting on its own weight again.
Apologies if you have posted this already, but did you replace the frame, box it in, or reinforce it in any other way? From what I understand, the frames on those really old jeeps twist a lot. Like, half the "suspension" travel came from the frames twisting up. You have a lot of money wrapped up into suspension to let the coilovers stay stationary and the frame twist around like a noodle.
