Very, very neat solution. It looks like it packages exceptionally well, too! I am looking forward to seeing it all detailed out.
Been tweaking things for a few days, but I'm closing in on a final version. Now just waiting for more parts from sendcutsend.
Very, very cool modern setup on a classic!
That may be one of the coolest things I’ve ever seen
Doesn't look like much has been done, just tweaking final design. It's like shoving 10 pounds of shit into a 5 pound bag. I've put probably 15 hours into this since the last post
View attachment 618172View attachment 618173View attachment 618174View attachment 618175
That packaging is phenomenal. What did you say, 14" of travel? With the coil overs laid down like that, it would seem to eliminate the clearance issues we usually see at full flex at the inside top of the stuffed tire. Other than having to figure all of this out for yourself, do you see any downsides to the configuration?
How'd you learn how to build a cantilever suspension. Just winged it? Followed an example? Used a book?
Brain too small to ask specific questions about the setup but dang, cool.
I've been thinking in over for a few years, but the basics are at full compression you want at the bellcrank to be compressing the shock at near to a 90 degree angle vs the push rod that is attached to the axle. The axle will have maximum leverage and the shock will also have maximum leverage to resist being compressed. You don't want the shock to be at a disadvantage while approaching full bump. I've watched a million vids, and read everything I could online... In the end it really just came down to what fit. The longer the push rod side of the bell crank, the more axle travel. But this Jeep is so small, I had to package everyone micro. I've seen Toyotas and full size trucks get two or three feet of axle travel out of a 10 or 12" shock.
I've seen your work, is just new to you. I have no doubt you could pull this off
