Git’r done Trevor! List looks good! I have some rear extended sway bar links and possibly some bushings. Have to look for the bushings.
Ryan actually gave me his after he snapped his sway bar! I just need to get on it and install them
It's a rhetorical question don't worry!
Here is my list but I don't want to do it in the gravel so it will start after I have a garage door. Hopefully.
I need to redo my upstairs shower, but I have jeep plans this winter.
Do I push the Jeep plans back, or do I shower downstairs until summer?![]()
I'm forgoing working on my Jeep in order to rebuild my deck. If they weather turns crappy then I can move inside to work on it. In your case thrown down a tarp and a heated blanket.
In your case, I would only do one thing at a time. Don't remove all the parts at once. Accomplish little wins at a time. If the weather is nice for a bit, work on the Jeep. If it's crappy, work on the house. If you only work on one Jeep project at a time, it will be easier to reassemble should you need it for something.
Speaking of the TR Flip, I’m trying to find the tapered insert for a Dana 44. Where do we get one? I’ve bought one before and still can’t find it.
EDIT: is it this one?
https://www.polyperformance.com/tfx-trdlts-parent-teraflex-tapered-insert-sleeve-for-jeep-dodge
TFX-990175
Who cares? I have a Dana 30.
Cool good googlin looks like that fits both.
Y, same for both. The shipping is stupid $$$
I don’t think that’s it. It doesn’t look like what I ordered before and it’s aluminum.
This is it! I kept thinking Polyperformance sold it. Nope! It’s TMR Customs.
https://www.tmrcustoms.com/products/tie-rod-end-inserts-jeep-taper-tj-lj-xj-zj-mj
Sorry for the slight diversion!
Ive got one of these in the garage somewhere. You're welcome to have it for shipping if you want.
TFX-990175
The wizard can probably hook you up with a finished knuckle for a great price
I don’t even know what a “finished” knuckle is. LOL! I ordered his 17” BBK and it comes with new knuckles. Are you saying I don’t need the tapered insert with the new knuckles?
I also ordered raised sway bar brackets and hoping to install all this soon. I better get out of Basket’s thread and get on my own.
You should give him a call, he has definitely swapped knuckles before with pre-tapered ones. IIRC the ones he swapped weren't the insert, they were just milled with the flipped taper.
