Yeah that's how I justify it in my head, I'd do it inside anyways this just keeps his fluff out my drainsit's so dumb. I see people washing their RVs so I don't care all that much.
The state of Colorado = sound reasoning above all else !
You underestimate his uselessness
I think i get your dry sense of humor![]()
if I ever get my hands on the retard that put the brake pads on this axle
At least you're using the warm weather to your advantage.
I at least drilled out some old nutserts
Now, if I ever get my hands on the retard that put the brake pads on this axle.......
That was entertaining as hell watching you struggle though that![]()
Yes when I build my workshop. It will have heated floors. I'm too old for the ground or cold concrete.It sucks ass every single time!
It sucks ass every single time! It's been years
How many times is that now? Better get that other lug off so you can take both tires off at the same time to swap them!
Definitely over 10! Can you just swap one pad of a pair from one side to the other? I thought you shouldn't so I haven't.
New sockets show up tomorrow for that dumb lug nut. All other 9 came off easily
I don't know if you "should", but if it were mine, I would unless there is noticeable uneven wear. It's not like you are introducing a new pad to a used pad, you're just correcting the orientation you messed up on the initial install, they've all been in service for the same amount of time. That's just what I would do if it were mine and offering my opinion, which should in no way be taken as a recommendation or advise. I am not an expert in brakes or their safety, but common sense tells me that I've seen idiots run their brakes to the point the caliper pistons are ground off, and they didn't die. Swapping a known good pad from one side to the other wouldn't bother me much.
Smart! Some people on here are so smart![]()
You're not one of them
Who needs smarts when you're persistent??
You should consider a career in fighting fire![]()
