If Chris got it 30 days late according to some he must have some pull getting it that quick
I doubt any aftermarket off road manufacturer is annealing and re tempering any aluminum, 6061 or 7075. The soak time to reduce hardness on 7075 Aluminum is about 2hrs on 3/8" sheet and about 4hrs soak to realign. Way too much expense for us cheap skates.Or to
Or to say that the are using 6061-T6, annealing it prior to bending and then re-tempering. Who knows but there are contradictions all of which a consumer may have no idea or knowledge of. Blaine supplied detailed info that will be used for my discussion with them come Monday.
Capitalism is the word you are looking for. Too bad it's a dirty word now.Are you getting a discount? That can perceived as a marketing fee.
Were is dirtwerx? We need to do a big bear run someday.For the rear, I have the Dirtworx steel. Again, functionality driven. Plus the Dirtworx guy lives about 30 minutes from me. I was able to pick it up and save on shipping.
Not to mention that any company who did that would not be the tiniest bit shy about advertising that little fact. Treated and tempered after fabrication to bring the whole structure up to T6 Temper.I doubt any aftermarket off road manufacturer is annealing and re tempering any aluminum, 6061 or 7075. The soak time to reduce hardness on 7075 Aluminum is about 2hrs on 3/8" sheet and about 4hrs soak to realign. Way too much expense for us cheap skates.
Amen! And it should. People don't have a clue what goes into a lot of this manufacturing. I used to not appreciate it at all, till I got close.Not to mention that any company who did that would not be the tiniest bit shy about advertising that little fact. Treated and tempered after fabrication to bring the whole structure up to T6 Temper.
Sorta like making a trackbar out of solid 4130. The only reason to do that is to heat treat it for higher resistance to bending and no one who pays for that will fail to mention it in the description of the part. It adds too much cost which will drive the price up and it will be listed to justify the price.
If you want to make that a tad bit easier, take a piece of plate and weld two pieces of 3/4 or 1" round bar to it for a quick and easy lower die. Even heavy wall tube will work.Here’s a piece of 6061 T6 that I broke (literally) with a small inside rad.
Here’s another with a larger rad.View attachment 229856View attachment 229857View attachment 229858
All this talk about bumpers has inspired me to make some bash plates for my GR bumper.
That’s a great idea, got just the scraps of plate and pipe to do it with too.If you want to make that a tad bit easier, take a piece of plate and weld two pieces of 3/4 or 1" round bar to it for a quick and easy lower die. Even heavy wall tube will work.
edit- if you want to keep the scuffs on the outside less noticeable, lay a piece of old t-shirt across the lower die.
My assumption after all of this is...they take orders (and money) until they have enough to do a run of them which is awesome if you are number 24 of the 25 quantity but crappy if you are number 1 of 25.I am more of a trail rider(Not really looking to push it to the limits in the rocks) I have a warn steel stubby. Its tough and good looking imo. Has performed its function just fine. Not a Savvy nut swinger but they have the best sliders on the market and its not close. And I want a set of those because they are awesome, not because they are made by Savvy. I don't understand time line issues. Its a scheduling issue as much as anything. Just gotta plan for things(I understand people gets rushed for various reasons)
Pretty educational thread.
Yes, Me personally. Its going to be a very slow process. And I don't mind waiting for things. I am in the camp that if I want a certain part on a machine of mine, I want that part. When I was younger I would jump on something and it not be exactly what I wanted. In which case I quickly figured buy once cry once is the way to go. I think if a small business can run a certain way based of me understanding what they need, Not a problem. Different strokes.My assumption after all of this is...they take orders (and money) until they have enough to do a run of them which is awesome if you are number 24 of the 25 quantity but crappy if you are number 1 of 25.
Pass me a Root Beer!The returns on the GR are smaller and a trapezoid shape so I won’t be able to put as many fasteners in it like the Savvy has.
View attachment 229893View attachment 229894
None of the aluminum bumpers of either brand have tow points on the face of the bumper but why would you want them there? Most stubby front bumpers are designed with approach angle in mind.With the Savvy one it looks like it comes only with tow hooks like the OEM bumper and no mounts for D-rings. I'm sure its not a problem out on the trails since it's top tier and all, but is there any real distinction between having tow hooks or D-rings? Is one just outright better than the other, and are there things couldn't do if you had one or the other? Just asking out of curiosity.
