Sold my old tub tonight! Cha-ching! Guy gave me 384 dollars and I gave him my old carpet. Savvy taillights are on the way
Happens. A lot. My entire rig is one bone headed mistake after another.After thinking about it all day, I think it will be OK. Its just a bit of extra work, as I'll have to throw the tub on, bolt the cross-member up to the tub, and tack the frame back in position. Its not a huge deal...but I was more pissed at myself than anything. I got in a hurry and made a bone headed mistake.
He gave me what was in his wallet. I was asking 400 obo. I could tell he wanted it, So I made him give me a number instead of me telling him how low I'd go...so, 384. I told him 380 was good enough, but he wanted to give me the extra!Happens. A lot. My entire rig is one bone headed mistake after another.
By the way - how did you come to $384 as the sale price for the tub?
Everything I do is made harder by rust.I think we need to name this thread the " hard way" build! Lol!
Sounds like a good signatureEverything I do is made harder by rust.
Impressive progress!Finished up my spring perch relocation tonight. Cherished checked everything at bump and it's all lined up nice... Though I am shorton my bump stops. To bad it's so hard to pull the tub... Makes getting this right a piece of cake.
You can see the first point of contact is my track bar into the cross member. That happens before my bumps contact. Gonna have to adjust that... But since I'm installing new shocks, I was going to have to to that anyway.
View attachment 237074View attachment 237075
After tacking them in, I was within a 1/4 inch at all four place I measured, so I burned em in.
Looking good. It's hard to tell from the photo but almost looks like corvette supersonic blue.
Wow that turned out great. Looks brand new.My frame is now painted. I'm a couple days behind my schedule, but I should be able to mount the tub this week. Here is the frame when I started...
Pretty representative. Every place there was a weld, or a hole, I have rust. Its pretty flaky inside too, but still has most of its thickness. View attachment 240952
I used Polycarbide discs to strip the rust and paint from the frame
https://www.amazon.com/gp/product/B086PFBKDN/?tag=wranglerorg-20
These worked really good. It took the paint and rust flakes off really easy.
Here is the frame after striping the paint
I used KBS coatings to paint the frame. Its a three step process, just like POR (which I've also used). You first hit the steel with amn organic degreaser. Keep it wet and scrub it for about 10 minutes. Rinse and let dry. Then you spray with a phosporic acid to "etch" the steel and convert the rust. They recommend letting the steel soak for anywhere from 20 minutes to one hour, depending on the rust. I went for the full hour. Then rinse with water again and let air dry. It will flash rust.
All the white stuff is what ever oxide is left when phosphoric acid reacts with Iron Oxide. Once this step is complete, you paint. Its a messy process...but the stuff is STRONG and pretty resilient once dry. I was using acetone to clean up some overspray from a different project and it didn't even remove the gloss from the KBS.
The paint goes on thick too...fills in a lot of the rough, pitted areas that the rust leaves behind. Its not perfect, but a LOT better than it was. I also have three cans of internal frame coating from eastwood to go in, but I gotta get the inside cleaned out. Been working at that a little here and an little there. I need to get the front end lifted up though, and get some help from gravity to really get her clean.
I have a couple areas on the tub to paint (front footwells are worn), I am going to replace my brake lines while the tub is off, and weld in some new nuts on the cross member for the rear shocks. Then the tub goes back on!
It really is a Shame that Chrysler couldn't figure out how to get the water and crap OUT of the frame. The outside is in really good shape. I'd say 75% of the metal is clean and smooth. Inside is a whole 'nother story though...They totally rot from the inside out.Wow that turned out great. Looks brand new.
Would a weld through primer have helped stop the problem you think? I read somewhere the other day that Chrysler doesn't use it but many other manufacturers do.It really is a Shame that Chrysler couldn't figure out how to get the water and crap OUT of the frame. The outside is in really good shape. I'd say 75% of the metal is clean and smooth. Inside is a whole 'nother story though...They totally rot from the inside out.
I was reading something, somewhere, that said the galvanneal steel (steel made with extra zinc to help it resist corrosion) is really great...until you weld it. The welding burns away the zinc and leaves an unprotected area. Judging by the way my frame and tub rusted, I'd say that is 100% spot on. Every spot weld was rusted. Then because they don't seam seal the outside, the seams collect and hold water, so they were rusty too.
I know cars are not supposed to last forever, and being that mine has been a rust belt vehicle for most of its 17 years, I'd say its in decent shape, but dang...it would have been nice if they had spend a couple more bucks and applied a seam sealer to the outside of the tub...and maybe designed in some openings for crap to get OUT of the frame. Their handling and access holes would have been perfect, if they went to the bottom of the frame!
No, not any more than just holding them against the axle. Been thinking thru how they install tho.@Mike_H man you are totally revitalizing the Jeep this year. Awesome job man. Have you checked the placemen/fitment of the "recent goodies" yet?![]()
