TJ Fest 2021 - Moab (April 24 – May 1, 2021)
Deadlines.
-Trim savvy GTS at the rear shock crossmember for trackbar clearance (1 hour)
-Hand throttle
-Couple of test runs
I think that’s it.
You forgot 4" coils!
Driving ability aside, you and I are probably pretty close to equal capability. You running Pritchett?
Yes, I think we are going to do it first thing in the morning on Monday. I think we are pretty close if you get the 4" coils on, just 33" vs 35". Of course another variable is my longer wheel base - which is both good and bad depending on the obstacle.
Haha.
If I do that I have to do shocks, adjust pinion front and rear, adjust trackbars front and rear, perhaps remove 1" bumpstop 🤪, oh, and extended front brake lines (which I 'm doing anyway). Geez.
Right now it's sitting pretty much perfect.
What to do, what to do 🤔
Haha.
#jeepproblems
Shocks you should measure, I did the 2" ranchos and they were still too long collapsed for the 4" coils. Thus began a rabbit hole. Once my 12" fox's ship the old ones will be up for grabs for the rear - unfortunately I am guessing mid summer and not before TJ Fest.
#jeepproblems
Dang. I'm still sitting on my 2" Ranchos. I have 5 up and 4.5 or so down (whatever the exact number is). I was going to try the Rancho's @Alex01 is using. I've got the numbers somewhere. A good reason to probably just sit tight and hit Moab with current configuration.
Reactions: D M and DrDmoney
Haha.
Run with us on Monday of TJFest doing Poison Spider and the gold trails. Then decide if Pritchett is doable on Wednesday. Don’t overthink it.
#jeepproblems
RS55241's? I just found out my left rear is seeping oil.
