@Chris, these Shocks are important since they are Savvy's current offering. I don't see them in the Table.
Front Shock
Savvy FOX-TJF4
Extended 25.150
Compressed 15.550
Travel 9.600
Rear Shock
Savvy FOX-TJR4
Extended 24.750
Compressed 15.650
Travel 9.100
FWIW, some of the shocks in the list are no longer available. If I run across them as I search, I'll send to you.Thank you, I'll update the list now since I'm finally back in the saddle.
I can’t say for sure since I didn’t take these measurements unfortunately.@Chris
Still loving this resource, thanks.
The "TJ Factory" entries for front and rear shocks ... are those true for all models? I would have expected a difference somewhere between SE and Rubicon.
There is no difference in suspension between Rubicon and non-Rubicon TJs.@Chris
Is that a front or rear shock? Where is the other front or rear shock to go with it? Having both would help![]()
nope, just a little extra bumpstop on the Dana 44 front axle.Thanks. I had been told that the Rubicon springs sit a little higher, to account for the 31-ish inch tires. No?
No. Many say that. But they are incorrect.Thanks. I had been told that the Rubicon springs sit a little higher, to account for the 31-ish inch tires. No?
There were several small variances in rates and lengths to account for the different weights of different packages. I don't recall there being specific Rubicon springs or Sport springs. The goal was just to achieve a certain ride height at the factory.Got it. But, the spring rates do differ a bit, right? At least, that's what I gathered from this (second post). But I guess that would still make them sit at the same level, once the extra weight is taken into account.
Here are all the Black Max shocks I was able to find as a fit for the TJ/LJ. FYI, there were some minor discrepancies, so all the numbers I pulled are from the "Specs and Kit Notes" tab. Also, the advertised lift heights don't seem correct, so it's best to cycle the suspension and measure. FWIW, I found their shock length numbers were true, at least on the B8525 and B8518 shocks I purchased.Is that a front or rear shock? Where is the other front or rear shock to go with it? Having both would help![]()
Front Shocks
B8516 (Front With 0 – 3 in. Lift)
- 22.3 in. Extended
- 13.52 in. Collapsed
- 8.78 in. Travel
B8525 (Front With 4 – 6 in. Lift)
- 24.30 in. Extended
- 14.52 in. Collapsed
- 9.78 in. Travel
B8549 (Front With 6 – 9 in. Lift)
- 28.75 in. Extended
- 16.56 in. Collapsed
- 12.19 in. Travel
Rear Shocks
B8508 (Rear With 0 in. Lift)
- 19.07 in. Extended
- 12.07 in. Collapsed
- 7.0 in. Travel
B8518 (Rear With 1 - 3 in. Lift)
- 22.71 in. Extended
- 13.93 in. Collapsed
- 8.78 in. Travel
B8528 (Rear With 3.5 – 4 in. Lift)
- 24.84 in. Extended
- 14.82 in. Collapsed
- 10.02 in. Travel
B8563 (Rear With 6 – 8 in. Lift)
- 27.33 in. Extended
- 16.05 in. Collapsed
- 11.28 in. Travel
Front Shocks
- 22.3 in. Extended
- 8.78 in. Travel
- 9.78 in. Travel
- 12.19 in. Travel
Rear Shocks
- 7.0 in. Travel
- 8.78 in. Travel
- 10.02 in. Travel
- 11.28 in. Travel
The RS55239 is the front shock. The rear is RS55241.Great resource here. I'm looking for this Rancho rear shock, but it appears to only be available with stud and t-bar mount combo (front style). Maybe it's a mistake for this part number to be listed under "rear" in the chart?
Or is there a rear version available?
