this does my work for meNow defend your position![]()
you got it buddyWell gentleman, i had my share of laughs, it was as good as every other time.
So, meet again in 30 days? Same place?
It would be better if we were to get folks to understand what controls the range of motion in a joint. It isn't the joint fully since the mount width is fixed at a specific width. It you want to get more rotation in a joint, you need to reduce the body diameter, narrow it up, or some combination of both. Ideally you want the largest joint you can get in the mounts to increase durability due to larger components that make up the joint. If the ball is too small, it wears the race faster since point loading is higher. If the ball is too big, the race suffers since it lacks sufficient thickness to be wear resistant and provide isolation. If the body is too wide, it bottoms out inside the mount before you get enough misalignment to be usable. If the body is too large in diameter, same thing happens.How can we stop having these threads? Serious question @Chris can we make a sticky or a thread in the resources about “what a control arm joint does and what makes a good one”? Or maybe “what determines flex and articulation” How can we most effectively get across to new people that shock length determines travel and that having 20 million degrees of range of motion in a joint doesn’t matter. Or we can keep posting retard memes and call it a day, idk
That’s great info. Of course there are many reasons why, but that helps tangibly explain to people why the Johnny joint is more durable. It is bigger with a bigger ball and race while still giving you all the misalignment you need and nothing you don’tIt would be better if we were to get folks to understand what controls the range of motion in a joint. It isn't the joint fully since the mount width is fixed at a specific width. It you want to get more rotation in a joint, you need to reduce the body diameter, narrow it up, or some combination of both. Ideally you want the largest joint you can get in the mounts to increase durability due to larger components that make up the joint. If the ball is too small, it wears the race faster since point loading is higher. If the ball is too big, the race suffers since it lacks sufficient thickness to be wear resistant and provide isolation. If the body is too wide, it bottoms out inside the mount before you get enough misalignment to be usable. If the body is too large in diameter, same thing happens.
What you are after is a design that gives you the most usable misalignment with the largest ball, thickest race, and heaviest body without compromising any of those aspects in favor of another. When all are in balance, that's a pretty nice joint.
yeah @Chris, that would be a great ideaHow can we stop having these threads? Serious question @Chris can we make a sticky or a thread in the resources about “what a control arm joint does and what makes a good one”? Or maybe “what determines flex and articulation” How can we most effectively get across to new people that shock length determines travel and that having 20 million degrees of range of motion in a joint doesn’t matter. Or we can keep posting retard memes and call it a day, idk
What would even be more awesome is if someone could post up an angle finder on a fully articulated axle with 14" of shock travel (not the same as wheel travel which is always more) and then show how far the joints are from bottoming out on the sides of the mounts. It isn't even close and then we would have a very clear understanding of why asking the right question is more important to see through all the bullshit that is out there.That’s great info. Of course there are many reasons why, but that helps tangibly explain to people why the Johnny joint is more durable. It is bigger with a bigger ball and race while still giving you all the misalignment you need and nothing you don’t
I don’t need to tell you this but it’s the metalcloak marketing that causes the bullshit. People that don’t know any better look at their website and all over it they say their joints have more flex than JJs and all the other competitors. People automatically think that flex will be actualized.What would even be more awesome is if someone could post up an angle finder on a fully articulated axle with 14" of shock travel (not the same as wheel travel which is always more) and then show how far the joints are from bottoming out on the sides of the mounts. It isn't even close and then we would have a very clear understanding of why asking the right question is more important to see through all the bullshit that is out there.
8 lug on a 6" bolt circle is much stronger than 5 lug on a 4.5" bolt circle.I don’t need to tell you this but it’s the metalcloak marketing that causes the bullshit. People that don’t know any better look at their website and all over it they say their joints have more flex than JJs and all the other competitors. People automatically think that flex will be actualized.
Not possible unfortunately. Look at all the stickies I’ve got for the most basic of questions. Guess what? No one reads them. People don’t want to read or research these days, they want immediate answers to their questions.yeah @Chris, that would be a great idea
You can make one, dump hours of your time into to, fill it with good and through details and it will not change this.How can we stop having these threads? Serious question @Chris can we make a sticky or a thread in the resources about “what a control arm joint does and what makes a good one”? Or maybe “what determines flex and articulation” How can we most effectively get across to new people that shock length determines travel and that having 20 million degrees of range of motion in a joint doesn’t matter. Or we can keep posting retard memes and call it a day, idk
I kinda like these threads, it's like a breath of fresh air from theNot possible unfortunately. Look at all the stickies I’ve got for the most basic of questions. Guess what? No one reads them. People don’t want to read or research these days, they want immediate answers to their questions.
That’s not to say it isn’t worth a sticky, but it is to say that it’s not going to stop these threads from popping up every now and then unfortunately.
This thread has had more good information in it than previous threads that I can recall.You can make one, dump hours of your time into to, fill it with good and through details and it will not change this.
At some point, someone will have a question, because they either missed a sticky or they did not find sticky being helpful.
What happens after question is posted, that is the problem.
There is some good information in this threads, some things i learned, some got me thinking. There is also plenty of clowning and personal investment into JJ vs MC debate with some people.
wadda mean unfortunately?... this is great!Not possible unfortunately. Look at all the stickies I’ve got for the most basic of questions. Guess what? No one reads them. People don’t want to read or research these days, they want immediate answers to their questions.
That is a large part of the problem. Folks by and large think that we are somehow invested in what you run. Personally it makes no difference to me whatsoever what you run. What I can't abide by is when you come up with bullshit built upon the bullshit to justify your choice. We didn't pick the JJ for any reason other than it was an option, it was relatively local, and they were different than what was out there at the time. It took several years before we learned that this was a pretty good joint. We didn't wear them out, they worked damn well, they were affordable, and it didn't hurt that they are pretty local.and personal investment into JJ vs MC debate with some people.
Almost forgot, part of the problem is dumbasses like you that think hex is special. It isn't, the minor increase in strength across the points doesn't make up for the sharp edges that get peeled off like butter in the rocks and hang up easier since those edges also dig in easier. They only use hex to be different, no other reason. They aren't the only company that knows hex bar stock exists. If it was a good solution, there would be a lot more companies using it.You can make one, dump hours of your time into to, fill it with good and through details and it will not change this.
Beautiful word choice- it is amazing the shortage of technical knowledge is so pervasive companies that make the product even ask- if it was blue versus red, etc I’d understand better maybe.pandering to ignorance
No you old fart-tard, i dont think it is special, it matters none to me.Almost forgot, part of the problem is dumbasses like you that think hex is special. It isn't, the minor increase in strength across the points doesn't make up for the sharp edges that get peeled off like butter in the rocks and hang up easier since those edges also dig in easier. They only use hex to be different, no other reason. They aren't the only company that knows hex bar stock exists. If it was a good solution, there would be a lot more companies using it.
