Interesting, the tnt ones look like they tuck up higher than the genrights. I’ve never seen them before
You have to look around and investigate products from other companies other than those suggested on here.
The very bottom looks like it sits higher but I’m seeing there may actually be more exposed vulnerable surface area than the genrightsCompare the shape, they don’t look to be higher to me with a straight line vs curved.
I don’t know a good way to measure these, so this is frame rail to the weld bead (which I know isn’t great)The very bottom looks like it sits higher but I’m seeing there may actually be more exposed vulnerable surface area than the genrights
This might be easier than getting the damn outer C’s around the frame, If only I could weld.It’s not as bad as it looks. It’s really just cutting and flipping the crossmember’s end pieces side for side (and flipped). Then get the skid into position and weld tabs to the frame that line up with the newly flipped ends. I’ll eventually redo mine because I think it’s worth gusseting them too.
I think you have enough friends that canThis might be easier than getting the damn outer C’s around the frame, If only I could weld.
I think you have enough friends that can. If we can find a high voltage outlet in Moab I’ll bring my gear to get it done there as another option. 110 won’t be quite enough for the frame and mount thickness.
I’ll be in a hotel in Moab, so you’re looking more likely. If not we should see if @ChevyKeith can link us up with Grandpa’s garage!He does but I'm 3 hours away and my garage is sort of full right now. I'm trying to pencil him in for spring next year.
I’m watching some welding videos. Trying to warm up to the idea. I bet my neighbor would let me borrow one of his machines for a few hours to practice. Maybe start getting some PPE.I think you have enough friends that can. If we can find a high voltage outlet in Moab I’ll bring my gear to get it done there as another option. 110 won’t be quite enough for the frame and mount thickness.
I’m having trouble with their website, but it’s@JMT do you have the link for the headlight buckets you bought with the turn signals in them?
My answer is to drink a beerI was just looking as some damage I have on my sliders yesterday...You and @Irun were in my head..."sand that down and paint it" Instead I went inside and had a beer! I need to drink to quiet those voices in my head!
You get the Irun seal of approval!
