Can't wait for someone with a 5 axis mill to make billet 4.0 blocks with sleeved pistons.
Jezza likely knows a good amount about this topic. I believe he said something about a 300hp build being a good balance for power and reliability. He would know since he's been pushing things I haven't seen others push things.
Also, if you make a legit boosted stroker, you then need to address the transmission. The second I think about this, it reminds me to leave things alone...whether that's a stroker or a boosted 4.0L.
Turbos also scare people off due to the belief that it will make the engine unreliable, so I understand where you are coming from.
Over the winter, I read that currently offered lifters are pretty much all made in the same place these days. Not sure if it's true, but it wouldn't surprise me. Reviews aren't great on any of the brands RA carries.
I would have gone with the smaller cam as well if it meant my build would be more reliable. Is that why you went smaller? I assume that his disappointment was based on him thinking that if you go with a smaller cam, then why do some of the other stuff you chose.
My EGTs stay in a nice range, so I'll likely sell the gauge when I install the slate gray interior.
Most of what I read stated that cooler EGTs mean slower flowing gasses for spooling up the turbo. Many guys wrap their exhausts to keep the heat in so things will flow faster. I wrapped things to lower the under hood temps for IATs more than to help the gasses flow faster, but flow is no problem since the piping goes from from 2.5" to 3" after the downpipe.
I'm not disappointed in my power and don't seem to have problematic heat issues. For that reason, I likely won't change things when I'm happy with the power and reliability of this package.
Years ago now, there was member who built a stroker to pair with his Banks Turbo...and ported things to add more flow. He later mocked himself for thinking he knew more than Gale Banks because Banks said their kit was built for a stock motor. He said that his stroker didn't perform well with the turbo, and he sold the turbo since he had just dropped $$$$ on the stroker. Bummer all the way around except for the member who now runs his turbo in the NE.
We know Jezza is running his turbo with a stroker. I haven't directly asked him if he'd suggest doing a turbo, stroker, or turbo'd stroker. That said, I wouldn't trust the 42RLE to stay happy with a turbo'd stroker. Would a manual hold up better?
Dang, sorry to hear about the engine going down. How did you get mud in there?
And provisions for roller rockers *cough* @Jezza *cough*![]()
Roller cam you mean?
There was talk on jeepstrokers a few years ago about research into a hydraulic roller retrofit kit. I think that 505 performance had one, but I wouldn't trust any of their stuff.
I used to have a wholesale account with Crower and I spoke to the rep there. I got the not enough interest and not profitable excuse.
I'm not sure if this is true or not but I was reading that the reason a lot of the aftermarket 4.0 cams fail is because the lobe is not wide enough.
That isn't so bad if the setup worked? It would be fun to build a 6500rpm strokera hydraulic roller cam setup was going to be $1200 or so for the parts needed to make it work.
If you have to have a hot rod I-6, I have the remedy, and it's boost ready and would probably be good for 10,000 RPM.
https://www.dartheads.com/product-category/blocks/toyota-2jz/
I do know that the functioning stock cam i just measured has places that the wear pattern spreads out to the full width?
That sounds like a 2JZ. Whatever it is, that looks like a fun ride.
A normal wear pattern should be a small line around the base, with an increase/taper to almost full width as the lifter rides up the lobe to the peak, then the pattern should reverse on the down slope. A higher spring pressure can take it to full width, and IDK if that's bad or not. If you're running full width significantly before the peak, like 1/2 way up/down the lobe, you have too much spring pressure. If you're riding full width on the base, you have other issues.
Most of the options for custom engine parts are far too expensive for the Jeep market. I priced a set of JE pistons a while back and they were almost $1500. A billet block would be $10k minimum and a hydraulic roller cam setup was going to be $1200 or so for the parts needed to make it work. Honestly at this point I would just do a lightly ported head with a stock cam and 1.7 ratio rockers.
Yeah,i wouldn't touch anything of 505's.
I just went out and measured a stock cam,5/8" wide lobe and roughly 1.25" casting thickness between lobes. I have heard the same thing about lobe thickness but also heard that it doesn't matter? I do know that the functioning stock cam i just measured has places that the wear pattern spreads out to the full width?
I've had and still have issues with lifters not holding prime. My nitrided cam is happy so far with a few lobes seating more than one new lifter?
I used russ's comp cam 68-231-4, 206/214 duration,.462"/.485" lift, custom ground 113* lsa for jeep fuel injection and nitrided. I think the larger russ 97-99 cam is a 68-235?(looks like SkylinesSuck has an even bigger one,the 235 is
- 210/218 Duration at .050". 111 Degree Lobe Separation Angle
- 0.477"/0.493" Valve Lift)
@SkylinesSuck is running this cam i believe?it sounds great. My cam card also said 68-000-x but it is really a 231 with 113 lsa
Interesting. I hadn't heard any of that before.
