Call Metalcloak, they'll have recommendations for starting on a LJ, I know they did for me. I started there and adjusted for pinion angles and caster from there.
Funny thing happened after picking up the Jeep from the gear shop. I knew that the speedo would be off a bit. I pulled out my phone and turned on the gps to check the difference. Wow. Much bigger than I thought. The gps said I was going 65 but the speedo said 90. I laughed at the thought of the LJ doing 90 mph. Funnier still was as I pushed the speed a little more, I discovered an apparent govenor on the speedo. At about 97 it cut power.
So is that really what it is? A govenor? Or something else?
I was really impressed with their tech support. I had a shop install my arms and totally made up the settings as they were going along. After several trips back to the shop I gave up on their ability to get it right. MC support was great working with me on measurements and settings.
Well.......there are a couple of reasons. One is that the TC is the last component of the driveline that has not been worked on. Two....it's making noise (squeak that is drive and speed sensitive) and I would have to open it up anyway. Three....since I'm already there, I may as well upgrade so I don't have to do it later.....if I decide to go taller on the lift..... :headbang:
So I got the lift installed.....and ONE fender flare......then I ran out of time. It looks awesome on that one side. Other side looks ridiculous right now though. I'll have some more time tonight to get the other side on.
Lift was a task. I feel pretty good about it though. It was the first time doing anything like this so it was a fairly big accomplishment for me.
I'll post some after pics when I get the fenders on it.
Good looking LJ Devil Dog!!
I have the Metal Cloak 3.5" on my 05 LJ and it flexes and rides amazing!!!
I retired from the Corps 3 years ago, glad to see a fellow Leatherneck enjoying an LJ!!
We are headed out to Hidden Falls this weekend for our final group run of the year. We are going to have a Thanksgiving dinner on Saturday after hitting the trails.
Gears are installed (5:13)
SYE and new drive shaft installed
Metalcloak 3.5” suspension lift installed
Oil pan skid plate installed
MetalCloak front and rear fenders installed
Transmission changed
New diff covers installed
Cooper 35 mud tires installed
Blue Monkey speedo healer installed
Curry tie rod and drag link
OME steering stabilizer
Left to finish:
Install rocker panel guards
Final adjustments for fenders
Still have a small vibration above 60mph. The vibe was terrible without the sye and new drive shaft. After it has calmed down significantly but it’s still there. Any ideas???
