This says colum shifter. I think that is for the steering colum ??? I may need to cancel the order or is it for the floor shifter ??That is a shifter cable. If it is a shifter cable for an a 97-02 TJ then yes you need it.
I’m not sure that looks right now that I’m getting a better look at it. Part number you want is MOPAR 52104142
That is the shifter interlock that makes you have to turn the key on to take it out of park.
and thats not something i need? correct?That is the shifter interlock that makes you have to turn the key on to take it out of park.
Only if you want to turn the key on to take it out of park.and thats not something i need? correct?
I would guess in the range of 100- 300 but I haven't checked prices lately. I've only seen one new PCM in the last 2 years.So on the pcm / Ecm / computer. For a 97 tj 4.0 w/ automatic , what should I expect to pay ? And are there companies that make new ones or are the OEM the best to look for ?
That’s the route I went and mine works.Found this one on eBay. Are these pcm more than likely good ? Or like anything else , your taking a chance ?
I'd go for it.Found this one on eBay. Are these pcm more than likely good ? Or like anything else , your taking a chance ?
Buy the lines for your year Jeep. So 97.So I have a 97 tj 4.0.
Donor transmission is 2002
My Radiator has hookups for transmission cooler lines.
My question is , What hard lines do I need to buy ? do I buy for a 2002 32RH transmission so it fits the trans ?
thanks
No, not at all. Sahara is a trim code, nothing to do with trans or motor except they did not make 4 cylinder versions.Another quick question.
a guy has a pcm for a 97 Jeep Sierra and had a 4.0 and a automatic trans.
my jeep is a 97 tj sport 4.0.
would it matter if my jeep was not a Sierra ??
thanks. !No, not at all. Sahara is a trim code, nothing to do with trans or motor except they did not make 4 cylinder versions.
a guy has a set of lines from a 97 for a 100 bucks. Should I buy them new or are used lines fine to buy?Buy the lines for your year Jeep. So 97.
You find new ones in stock, point me to them so I can buy a set.a guy has a set of lines from a 97 for a 100 bucks. Should I buy them new or are used lines fine to buy?
