it's next on the list!
have you determined what steps you will do first? or are you doing it all at once?
cant wait to see itI'm just going to do it all at once.
Engine/tranny skid.I have done the body lift and the savvy gas tank skid. Being on a budget, what should the next step be ?
Why the Tcase skid before the engine/tranny skid?Transfer case skid in my opinion!
Probably because I can’t stand how low the stock skid hangs. Mine is like a damn mud shovel constantly being filled with mud whenever I go off-roading.
Yes, you need to do the MML, SYE/ DC Drive Shaft/ Rear LCA/ Rear UCA/Body Lift (You have the BL covered) all at the same time in order to be able to run a nearly flat t case skid. The only way to avoid the MML is to do something like LoPro which introduces vibes.If you do the tranny skid , do you had to do the sye and motor mount lift at the same time ?
Engine/tranny skid.
I did do a Metalcloak oil skid after i punched in my oil pan.
Check out this thread: https://wranglertjforum.com/threads/oil-pan-skid-plate-pros-and-cons.7478/I did do a Metalcloak oil skid after i punched in my oil pan.
What is your budget? Without knowing more all I could say is MML.I have done the body lift and the savvy gas tank skid. Being on a budget, what should the next step be ?
Yes, a MML goes well with a BL and helps correct rear driveline angles if you have a suspension lift. It won't affect anything else. How much suspension lift do you have? What size tires are you planning to run?Could I do the MML on its own without effecting any thing else ? I have to get new tires and perhaps fenders so I am just looking at the most bang for the buck.
Sent from my SM-G935W8 using Tapatalk
