I already have a body and motor mount lift, adjustable control arms, rear track bar relocation (soon to be antirock in the rear too), and t case cable. Still need the the driveshafts, SYE, and skid. For the rear shock relocation brackets, and the spring perch, is there any benefit in my Jeep being an LJ, and having adjustable upper and lower control arms that would prevent the need for either of them?
With the exhaust mod, would the exhaust be an issue after the tummy tuck, or after the motor mount and body lift? I don't seem to have a problem with my exhaust now, so I'm wondering if that means I'm okay once I do the tummy tuck.
Last, I'm looking to do a high pinion front axle swap. It seems like the drive shaft will be a few inches higher. I don't have any issue with my front drive shaft now, with a low pinion, 4" lift, and motor mount lift. But I probably will with a tummy tuck. But, if I go to a high pinion, is it possible that I won't need a new front driveshaft?
