You beat me to it...
You beat me to it...I've had both the Pontiac slant-four and the International slant-four in my family. A '63 Tempest and an early Scout (forgotten the year). Both are cool little engines!
I can drive a flatty until it's shift time , then you pull your knee past your ear to put your foot on the clutch pedal .![]()
I guess a V6 in a flatfender has been a thing for a while. I recently met this guy on a club trail run in OR (the Oregon CNT event on the Mcgrew trail). I'm no expert on this era of Jeep but I think he said it was a '42. At some point, it got a Buick Dauntless V6 and also had some odd looking early d44s.
Here is the engine. Check out the "odd fire" distributor, apparently adapted from a V8 with 2 blank spots without plugwires:
A search says this is a 160hp motor. That's better than the 60hp L134 flathead "Go Devil" you have now but way down vs the 4300 vortec you are planning. Guys who frequent the thread about other cars ( https://wranglertjforum.com/threads/car-pics-too-cool-not-to-share.59109/page-1924) like @Squatch, @ColoJeep, @BlueC and others could probably tell me a lot more about either of those V6s.
Correct. It should be noted that the earlier Buick V6 (198) doesn't share many parts with the 225. It was based on the 215 V8 platform. The later 231 odd fire Buick shares a lot of parts with the 225.Basically, they just cut off 2 cylinders from the V8. With a 225 ci V6, it must be cut from a 300 ci V8.
I really do need to figure out what axle I want for the rear.
Why not a Dana 44 offset for the D18? Go 30 spline or 33 spline or 35 spline for the added strength... Locker or a TruTrac
Here's what I've come up with. Dana 44 rear. Cut off the axle ends to narrow and offset. Then weld on some set 20 bearing cups. Have 30 spline semi float 5x5.5 axle shafts made. Figure out how to adapt my current disk brake setup
Still, this has to be one of the coolest flatties on the planet, who's with me?![]()
Why not go with a full float system? When I was building a Dana 44 for my Samurai that was what I did.
30 spline kit: https://hermtheoverdriveguy.com/30-spline-full-floating-axle-kits
19 spline kit: https://hermtheoverdriveguy.com/19-spline-full-floating-axle-kits
Just an idea...
Since I'm not totally familiar with the older Flatties, are they narrower than the old CJ5? I'd always thought they were the same width.
I've said before this is my favorite Jeep here. While not a TJ/LJ, what Kris did is "Flat-out awesome!", pun intended!![]()
Thank you!
