SwayLOC vs AntiRock
No problem.
Just for a little more information/reference for anyone looking at this. The Motobilt bumper has 2.75" of clearance above the frame.
The inner bar has a part that sticks about 3" above the frame which would have been into the bumper where the grille hoop comes down.
To be fair, your motobilt bumper doesn’t clear the sway lock. I’m running a motobilt bumper and have no issues with clearance to the sway lock. They make multiple styles of bumpers, so saying, “the motobilt bumper doesn’t clear,” is a bit misleading
I do think I said the Motobilt bumper I have has wings on it. But to make it more clear I went back and edited it.
I hated the effects of the stock bar on the road . Everytime you crossed over a slight incline diagonally it rocked ya back and forth which I felt was annoying . With AR that was gone and actually rode better on the road I felt . I run it on the loosest setting and Rancho 9000xl set on 3 . I have no complaint on or off-road . No wandering . Tires are 35-12.50-15 Maxxis Big Horns at 36 psi . Been great for the last 15 years with this combination . No need for me to experiment as I have no complaints at all .
Post pictures of your bumper from the side and it will help in seeing if it you have the room.
I have a Motobuilt bumper and the way the wings of the bumper come up over the sides of the frame makes it very hard for the SwayLoc to fit.
EDIT: Just to be CLEAR this is only one style of bumper made by Motobilt.
The inner bar on the passenger side is what can cause a problem.
Here are a couple of mine, what do you think about clearance issues ?
Thanks for any help you can give
Looks good to go from here.
I don't think you should have any problems with it hitting the bumper.
Reactions: Moglocker
Looks like you have room for a SwayLoc and a couple cans of soup in there. If not, cut stuff.
3/4" from top of AR to lip of bumper. SwayLoc is in the shop in the box.
Currie bumper. Cutoff wheel time?
Funny I didn't notice anything when cycling the suspension for shocks and bumpstops. Or maybe the AR was disconnected.. I've exhaled since then.
I'll cycle before moving the bumper for SL install.
3/4" from top of AR. SwayLoc is in the shop in the box.
Cycle the axle and find out.
