Hi all,
After what feels like endless research, I believe I’m ready to see what you all think of my build plans. I recently acquired a stock 2005 Jeep TJ Willy’s Edition with 96,000 miles. It has the 4.0L engine with a 6-speed manual. It will become my winter/bad weather daily driver as well as off roader for Rausch Creek, AAOA, and FRO. I’ll probably put 5,000 miles a year on it, mostly commuting to work on backroads and the occasional highway use. Hopefully get to the parks 5-10 times a year. I do not plan to do crazy rock crawling but want to be prepared in case I follow some friends down some tough trails. I will have to drive the Jeep back home, so I want it as reliable as possible. I should also mention my goal is to have this built within 60 days.
I’ve considered the 8.8 and Dana 44 swap, but I don’t think timing wise that will work for me and that probably opens a different can of worms I’m not qualified to deal with. If I had a Jeep specialty shop installing everything, maybe I’d be comfortable with that. I plan on having my go-to shop that works on my other cars do this build. I’m thinking I drive on this build for a few years and go bigger down the road.
I think I’ve hit the major points but am I missing anything small or complimentary to the others?
Other considerations:
- Rubicon Express 4.5 inch Tri-Link Long Arm Suspension (open to suggestions on lift kit but don’t want to spend crazy money here)
- Alloy USA SYE Kit
- Rough Country Rear CV Driveshaft
- G2 Axle Gears Master Install Kit Front and Rear – 4.56 ratio
- Alloy USA Front Grande 30 Spline Chromoly Shafts (Revolution out of stock for front kit)
- ARB Air Locker for 30 spline Dana 30
- Revolution Gear Super35 Kit with ARB Locker
- Air compressor (any suggestions as to which one and where to mount it? Engine bay?)
- I will eventually get a new front bumper and winch.
- I have a rear bumper already with tire swing receiver for the 5th wheel. Don’t know what brand.
- Truss kit for Dana 35? I’m seeing the Rock Krawler weld on rear cradle but I’m not sure if there’s anything else needed for that. Is a truss overkill or worth the extra insurance for a few hundred bucks?
- For the lift kit – should I go without shocks and get Bilsteins separately or get the shocks provided in the kit. Any major difference between twintube and monotube?
- Should I add or subtract anything from the above list?
