So far the score appears to be 458-2 in favor of Wranglerfix.
Yes sir I do have an LS. The Jeep PCM does not control any of the engine. It even runs great even without the PCM in the car or hooked up.Is there more to this story? Don’t you have an LS?
So how did wranglerfix do you wrong?Yes sir I do have an LS. The Jeep PCM does not control any of the engine. It even runs great even without the PCM in the car or hooked up.
I would keep a smile on my face and not say anything other than that I will not give him any stars.So how did wranglerfix do you wrong?
So why say anything at all?I would keep a smile on my face and not say anything other than that I will not give him any stars.
You just can’t make an angry elf happy!So why say anything at all?
I totally recommemd a WranglerFix pcm if you have an automatic Tj thats shifting hard or throwing up generic transmission codes.. its a very specific and known flaw in the stock TCM(tranmission control module) which is part of the PCM..Everyone has there good and bad experiences. I would never, never recommend Wranglerfix. I would recommend SOS Diagnostics.
Or a manual throwing codes constantly, and you’ve traced all your ground. Usually about all the O2s and sometimes more.I totally recommemd a WranglerFix pcm if you have an automatic Tj thats shifting hard or throwing up generic transmission codes.. its a very specific and known flaw in the stock TCM(tranmission control module) which is part of the PCM..
Been a while, and I was wondering if any more thought had been given to turbos and superchargers?It comes with stock programming. I don't
It looks like spellcheck got me. You can adjust tires, gears and speedometer with a tuner. Software cannot be updated and no turbos or chips.
Unfortunately, nothing on the superchargers or turbos.Been a while, and I was wondering if any more thought had been given to turbos and superchargers?
I have had this happen on a handful of Jeeps. Is yours throwing any codes or just flashing security?I purchased your unit and solved the hard shift problem but now my warning light for the key stays on. Any idea on how to solve this issue?
Ordered from @Wranglerfix (Mark) on Tuesday and received on Thursday. Installed it today. I’ve only put 15 miles on it so far just running out to get some oil and filter for an oil change and got some lunch.
So far, so good. Smooth shifting. No codes.
Thank you.Add another satisfied customer of Mark and Wranglerfix for a 2005 automatic LJ.
@Wranglerfix @thump365Hey guys,
I’ve got a new one for you. My 04 LJ will suddenly give me a CEL and go into limp mode ( 2nd gear only, no OD light, etc.) I stop and do the key routine and got the generic PO700. Start it up drive away normally (no limp) CEL still on, got to my Jeep mechanic to read any codes. Shut off engine to connect reader and the CEL is gone and no codes are stored. This is the second time its happened.
