Basket's Build
jjvw
We are MegaJeep!
Colorado, USA
This assumes track bar and tire clearances are all ok. A little bit of tire rub at the edges of travel and steering is fine.
Reactions: JMT and lBasket
lBasket
lBasket
Branch Manager
Aurora, CO
Make the cup touch the axle pad. The jounce will compress.
Okay cool so that last pic is with shock fully compressed, so I guess since that edge that is 3/4" gap is actually off the pad a little bit, I'm aiming for about 7/8" of bump? Would you bother shaving 1/8" off a 1" hockey puck for that?
TB is loosely connected, no interference there. Checking tire on this side next
Reactions: jjvw
jjvw
We are MegaJeep!
Colorado, USA
I would make the shock be the limit to travel. That means your extension is no more than 3/4". 5/8" would be fine.
Double check all this with the axle fully raised, both sides.
Reactions: lBasket
lBasket
lBasket
Branch Manager
Aurora, CO
Okay cool, thank you for the tips!
Reactions: jjvw
lBasket
lBasket
Branch Manager
Aurora, CO
Lots of interference on the tire at full left turn and shock fully compressed. A little bit thoughout maybe 80% of the turn radius and can still turn it by hand so that's probably fine but right at the end of left turning it is really jammed up against the fender
So what's the approach here? Back if off in tiny 1/8" increments and stop when I can turn the tire by hand (little bit of interference ok)?
jjvw
We are MegaJeep!
Colorado, USA
First bring the tire to trail pressure. If you can spin the tire by hand, don't worry about the rub.
Do you have an adjustable track bar? If so, are you sure the axle is centered?
Reactions: lBasket
lBasket
lBasket
Branch Manager
Aurora, CO
Ah didn't think about the tire pressure, good point!
I do not have an adjustable TB in front yet. I do still have the spacers on too, would removing them help?
jjvw
We are MegaJeep!
Colorado, USA
Wheel spacers? You want no less than 3.75" backspacing. 4" would be nicer.
You are in the fitting stage where you are finding and understanding the boundaries and making it all fit the best it can.
If the track bar is creating big tire interferences, figure what you need based on that. Revisit reducing the bump later on.
If you end up with unused shock travel, add a couple of your old cup washers to the underside of the upper mount to recover some down travel.
Reactions: lBasket
lBasket
lBasket
Branch Manager
Aurora, CO
Yeah the 31s we're wayyy too big for the stock suspension and I lost a lot of turn radius so that's why they're on there. I'll take them off and see how things fit without them
If one side has a lot of rub and one has none or much less, that points to my TB being a problem?
This will trade up travel for down because I am looking for as close to a 50/50 split as I can get right?
jjvw
We are MegaJeep!
Colorado, USA
Or not enough backspacing for your tire width. With no bump stop extension, stock track bar and a wide tire, the driver's side can rub at full compression. But the more lift you add on a stock track bar, the more the passenger side can rub at droop. It's a balancing act. Really, all you need to concern yourself with is getting the axle centered at ride height and having sufficient wheel backspacing, which likely requires wheel spacers
Do the best you can to get 50/50. At the end of the day, you might not get that. Adding the cup washers from the old shocks is just a way to get all of your useable travel put somewhere.
Remember, you can also adjust the lift height with small spring spacers to fine tune the shock travel bias.
lBasket
lBasket
Branch Manager
Aurora, CO
I have these rims w/ 1.5" spacers... does that give me 7" backspacing? Or am I adding the wrong direction lol
What is there to rub on at full droop? Is it the track bar on the axle?
Ah okay... so while everything is mostly apart I need to measure my shock at full extension, and then compare that to what is showing at normal ride height so I can see what my up/down bias is.
This is more complicated than I thought, lol.
Alex01
Itching For Some Rocks
Martinez, CA, USA
Spacers push the spacing the other direction. So you should be at 4".
Reactions: jjvw and lBasket
jjvw
We are MegaJeep!
Colorado, USA
Don't worry about full droop except to take your travel measurement, to see how the brake hoses are doing at full steering lock, and to make sure the drive shaft spins freely (it does).
Reactions: lBasket
lBasket
lBasket
Branch Manager
Aurora, CO
Okay cool. I'm kinda getting the impression I really need an adjustable TB up front too to do this right?
Reactions: JMT
jjvw
We are MegaJeep!
Colorado, USA
It's the BDS 2" lift but sounds like you net 2.5" from it, not sure exactly where to measure to find actual lift I got from it
Top of the spring to the bottom of the spring.
Either way, the stock track bar is probably only shifting the axle about 1/8".
lBasket
lBasket
Branch Manager
Aurora, CO
Okay so this is as close as I can get to full compression of the shock and still being able to turn the tire by hand @10psi. So this is when I'd want to space the shock top mount down a little bit (rather than just using bumpstop to stop the uptravel) to maximize usable travel?
Reactions: jjvw
