Ford had an online deal that you plugged your VIN into and it output all the details, seems to be gone now.Oops, that's F250 Tremor... Page 6 is a little confusing but either 21,900lbs or 12,400lbs for the F350 Tremor?
It's confusing and there are errors in their towing guide. It's been debated on the tremor forum.I did not know about the sway bar and was assuming it was the tires but I think they are load range E.
There's also no difference in the F250 vs F350 Tremor other than badges.
Bumper is 15k and gooseneck is 22k on mine.I can't imagine that it's rated higher for bumper pull than gooseneck.
Wouldn't the F250 be cheaper then?There's also no difference in the F250 vs F350 Tremor other than badges.
Most importantly it looks good, IMOYeah, that should be more than enough for any trailers I'm looking at.
They don't need to be, remember that 22k isn't all on your rear tires...Are the Duratrac tires good for 22k?
It's less than $1000 difference but you do get higher ratings on the F350.Wouldn't the F250 be cheaper then?
That's the factory tire so it's rated for that load.Are the Duratrac tires good for 22k?
wouldn't want the 1 ton some places such as California.
And they are asshats when it comes to out of state vehicles towing!!!I wouldn't want a trailer in California period. Speed limits suck coming from 80mph across the country down to 55mph.
I didn't slow down when I was out there? I outran most everything.I wouldn't want a trailer in California period. Speed limits suck coming from 80mph across the country down to 55mph.
I had no issues, except finding DEF at a pump. It's the only time I've filled the truck with a jug.And they are asshats when it comes to out of state vehicles towing!!!
you lucky sumbiatch!!!I didn't slow down when I was out there? I outran most everything.
F250 and F350 tremor physically the same but higher tow ratings on the 350? Thats dumb.It's less than $1000 difference but you do get higher ratings on the F350.
