Does anyone know if I’ll need the savvy shift cable? On 4” springs + 1.25” BL.
Rather order now and start the waiting game if need be
You can adjust the stock TC shifter to work if you want to, but the cable is much better. It's worth it, IMO.
it’s expensive but significantly less than buying a new JL / JT.
I can go Currie if you all think it’s worth it, but it seems a little absurd to put $300 of bump stops on.
I’m going to need extended bump stops for the suspension set up I’m intending on running.
I’ve seen the DIY hockey pucks and the Currie options. What would you all recommend?
Any other recommendations or should I just pay up?
Also need recommendations for rear extended sway bar links. I’m going Swayloc in front and figured I’d throw on extended links in back to see if I even needed / noticed not having Swayloc/antirock in rear.
JKS has some for $100. Currie / Savvy have some for $48. JKS look to be adjustable, Currie and savvy look fixed.
Any recommendations there?
You're gonna need to start installing this stuff pretty soon... or build a bigger garage?At this point my entire garage is parts
Or be like me and have parts scattered throughout the house. The mounted 40's are currently in the kids play room.
Anyone have recommendations on best shocks to pick up? Ive heard good things about the Rancho 5000x series.
Summary of build (once all installed) for suspension stuff
LJ with 4" currie springs, 1.25" Savvy BL. Savvy Control Arms, Currie trac bars, Swaylock up front, extended links in rear.
I decided against outboarding so keep that in mind. Looking for recommendation on stock placement shocks
I can't speak personally on the Rancho shocks but I'm sure someone will chime in. The good news is at 4" lift springs you'll have plenty of options.
Front Swayloc is on the way. Getting pretty close to installing all these fun parts
