Work from home LJ
first few setups it took me forever to get the pinion out and switch up shims. Now it’s just a few minutes at most.
Doesn't it feel good when you get to that point👍
It looks like 31 or 32 will be your number for sure. Strong work sticking with it.
Reactions: SvtLdr
Here’s .032. I like this a lot. There’s a very thin line across the top on both drive and coast. Pretty centered. I know we’re nitpicking at this point but might as well do it right
Reactions: Mike_H
Asking a stupid question while I wait for pizza.
I put pinion nut on and started just barely with an impact. I’m sure I haven’t started to crush crush sleeve yet.
I’m well aware I shouldn’t overcrush sleeve but I’m guessing I’ll feel it start to crush in the impact/slight pulses with impact and checking with my hand?
I have inch pounds torque wrench and all that. I know spec, just curious if it’s obvious when it starts to crush or you just have to check every 10 seconds or so.
It will get to a point where it collapses very quick. 10 seconds is wayyy to long once you start to feel it tighten up. Once you know it is making contact, I go in like 1/2 second bursts and feel with my hand. If in doubt, I check with the torque wrench.
Reactions: SvtLdr
Yeah 10 was a way exaggeration. I just haven’t felt it tighten up yet. So I’ll stop worrying about it.
ha I am watching the end of your Dana 30 video right now
A tip from someone who just did this the first time:
Make sure you dont have anything on the yoke. I had a homemade tool holding it and that led to my reading being way off (and me being close to over tightening but not feeling sleeve crush).
Once I removed that tool I was able to get accurate reading (and see I was WAY under spec) and then just slowly walked up to 12-15ish inch pounds with half second impact turns
Get ready for the feeling of MAXIMUM SATISFACTION. Good job staying patient. The next gear setup will go more quickly. 👌
  • USA Proud
Reactions: Illiquid
Thought I was going to pick up a hpd30/Dana 44 for a steal of a deal today but my guard was up with how cheap deal was.
That + guy wouldn’t agree to take a cashiers check in his name = pulling the 44 under my LJ to regear it instead.
(I don’t have any need for the hpd30 but guy wouldn’t separate)
I’ve been thinking of going to 33’s sometime in the future. When I do, I think I’m going to take the route @kameronkales took and regear this one and just swap it out.
Reactions: BlueC and sab
No real updates in the last week. I learned the (hard way) I need knurled ball joints for new axle.
Amazon has decided 2 day prime = 5+ days so whenever joints show up I’ll button the front end up.
Got a few projects to do on my truck this weekend while I wait for parts
Why do you need the knurled ball joints?
