Or steal themNice. I always carry an extra set of tie down straps on the trailer. The paranoid part of me always expects some asshole to cut my straps while parked at the hotel overnight…
I have those same nightmares!Nice. I always carry an extra set of tie down straps on the trailer. The paranoid part of me always expects some asshole to cut my straps while parked at the hotel overnight…
Connect it to onboard airI've had Bartact seat covers for the last 6+ years. When I originally installed them I didn't know about the option for lumbar support, so I've done without. No more though, and they are installed. Super easy install and once I sat back in the Jeep, it was like having new seats!
We are in Pa.Where you wheeling at?
Ouch.View attachment 262221
I’ll be watching to see what you come up with. Mine have seen better days…
The current state came to be as a result of wheeling the Jeep harder than ever before. More time on the rocks, not enough control of crawl ratio, more off camber situations, and losing a couple tires resulted in:
- 241OR installation
- Advance Adapters Rubicrawler
- Full Bolt In Cage
- 35" MTZ P3 Tires on Walker Evans Beadlocks
- Currie Antirock
You will love these straps!!!The LJ got new tie down straps, an oil change, and checkup for an upcoming wheeling trip.
So how do you like the hitch and how does the trailer pull?I definitely do! Had a chance to use them and the Weigh Safe hitch for the fist time. The straps are 100% USA quality and the direct hook option made it much easier to tie the Jeep down.
I was hesitant to spend the money on one of these, but it was a smart decision to do so. The previous setup I was using, all steel, only had a max tow rating of 7,000 lbs. The all aluminum Weigh Safe is rated at 12,500 pounds, which is in excess of my 11,400 lb 1/2 ton truck tow capacity. The hitch also weighs the same as the old steel one, but the height adjust-ability and swapping balls couldn't be any easier.So how do you like the hitch and how does the trailer pull?
I've had the same hitch for over a year now. It's awesome but I bought it knowing that gauge is crap. Mine hasn't worked correct since I bought it. I flip the ball around under the hitch when not towing so I don't hit my shin on it.I was hesitant to spend the money on one of these, but it was a smart decision to do so. The previous setup I was using, all steel, only had a max tow rating of 7,000 lbs. The all aluminum Weigh Safe is rated at 12,500 pounds, which is in excess of my 11,400 lb 1/2 ton truck tow capacity. The hitch also weighs the same as the old steel one, but the height adjust-ability and swapping balls couldn't be any easier.
To be honest, the tongue weight gauge doesn't seem accurate at lower weights. I tried playing around with vehicle placement on the trailer and the gauge would jump from 150 lbs to 500+ very quickly. Eventually, I was able to get it to read just under 500 lbs and the trailer towed better than it ever has.
Bottom line, thanks for pointing me in the direction of the Weigh Safe hitches. Similar to the decision to buy an aluminum trailer, this purchase was one I don't regret. It's safer, easier to use, Made In USA quality, and takes the guess work out of where to put the weight on the trailer!![]()
