Fried pickles are da bomb
We also drive too fastTeam Coco is cool AF (shh, dont tell anyone).
As well-built rigs should.We also drive too fast
That wasn't a secret. We made it very clear, but very few believed us.We also drive too fast
I can eat pickles on this team right?
On the record or offTeam Coco is cool AF (shh, dont tell anyone).
Team caca?
I set the fronts both independently at full articulation. Make sure though that they'll still work at full bump though because fill articulation may allow to to go a bit shorter than you should. (Fast driving offroad and hit a whoop you'll need full bump. Flexing you'll need full articulation. )Soo when I am checking to set bumpstop do I want to lift just one side of the axle at a time? Or from the center? Or maybe both and pick the max bumpstop required for both?
Everything you can think of.Soo when I am checking to set bumpstop do I want to lift just one side of the axle at a time? Or from the center? Or maybe both and pick the max bumpstop required for both?
Ah okay so make sure bump isn't too short with both sides pushed up?I set the fronts both independently at full articulation. Make sure though that they'll still work at full bump though because fill articulation may allow to to go a bit shorter than you should. (Fast driving offroad and hit a whoop you'll need full bump. Flexing you'll need full articulation. )
Sweet, get creative.Everything you can think of.
What is keeping the shock from reaching full compression?Looks like I need 1" of bumpstop over here. That's nice i wasn't excited to try to to cut a hockey puck in half with a hacksaw
I read on the how-to guide I want set bump so there's ~1/4" left of shock, so I backed off a bit after it bottomed out. Is that right?What is keeping the shock from reaching full compression?
Take it to full compression.I read on the how-to guide I want set bump so there's ~1/4" left of shock, so I backed off a bit after it bottomed out. Is that right?
Okay this is what I get fully compressed. Will the jounce fill that space or will it compress farther than that?Take it to full compression.
Make the cup touch the axle pad. The jounce will compress.Okay this is what I get fully compressed. Will the jounce fill that space or will it compress farther than that?
