It just happened!
GenRight parts started arriving. Received the LJ corners, along with the inner and outer front fenders. The rear flares will arrive next week. Also received the BMB 3 wire marker/turn signal lights. Once the TJ is gone to its new home, I'll start on the installation of these and other parts.
Have sold it? I know you reasoning, but IMHO a real shame given how much amazing work you put in to it.
Long story there. The short version is it's going to my oldest son. He's turned his life around and I'm proud of how far he's come in the last couple years. He's been spending some time wrenching with me lately and I believe he's now in a position to appreciate and care for the Jeep.
That said, we got a little work to do to get it set up for his use. We've already dropped it in height, went with a 2" set of springs, and set up shocks to match. The 241 case will come out and I've built a 231 with a SYE for him. There's more than that, but details will follow, at some point.
That said, we got a little work to do to get it set up for his use. We've already dropped it in height, went with a 2" set of springs, and set up shocks to match. The 241 case will come out and I've built a 231 with a SYE for him. There's more than that, but details will follow at some point.
Well, we know you won’t have to clean it…
That's a great outcome, both in terms of your son getting things sortex and the TJ that you have put so much time and energy in to going to the best possible next owner. I am sure you are both making some great momories together working on the TJ.
Reactions: JMT, RINC and Irun
After fighting with the snap rings on JJs, because I only have a small multi-tool plier, I broke down and bought a nice snap ring plier set. This is a HF Icon set that is on sale for members. The quality is surprisingly good and the price was right, at $59.
I bought an ICON 50-250 ft/lb torque wrench a couple years ago and the quality of it seems really good too, even the case.
Reactions: Irun and Wildman
I have the same set, bought it last time they had a sale on Icon tools. Last time I tried using my channel lock set of snap ring pliers I wanted to throw them, so I upgraded. Haven't used em yet, but they do feel nice in the hand.
Reactions: Irun and SvtLdr
I've updated my spreadsheet and included it in the first post. Part of the reason for doing this is to better organize what I've done, and what's left to do. The other nice thing is I can now start to link work done to specific places in my build thread. That will make it much easier to find things. For this go round, I've only linked to a few, just to get started.
As a side note, it's amazing how quickly things adds up. Having built a few Jeeps over the years, prices for everything have gotten stupid. I used to be able to buy a Jeep, fix it up, then sell for a profit. I did this for years, to pay for my own mods. That is no longer practical, given costs after COVID. 😒
2004 JEEP WRANGLER UNLIMITEDCOLOR = SHALE GREENNOTESFORUM LINKS
EXHAUST
NTK23137Oxygen (O2) SensorNot Installed
NTK23135Oxygen (O2) SensorNot Installed
NTK23132Oxygen (O2) SensorNot Installed
NTK23531Oxygen (O2) SensorNot Installed
WALKER36530Ehaust Clamp
COOLING SYSTEM
CONTINENTAL49039Idler Pulley
CONTINENTAL66692Radiator Hose
CONTINENTAL62394Radiator Hose
CONTINENTAL64418Heater Hose / Pipe
CONTINENTAL64419Heater Hose / Pipe
CONTINENTAL49256Belt Tensioner
FEL-PRO35630Thermostat / Thermostat Housing / Water Outlet Seal
GATESCO34741Thermostat Housing / Water Outlet
STANT45359Thermostat
STANT10334Radiator Cap
MOPAR5503 7653ABRadiator
OMIX17105.12Fan Clutch
MOPAR5012366AFWater Pump
DORMAN56398Water Pump Inlet TubeOrder # 144016717
FELPRO35629Water Pump GasketOrder # 144016717
THERMOCURETC001Coolant System Rust Remover
GASKETS, SEALS, FLUIDS, ETC.
RED HOUND‎2946079Valve Cover Grommet
DORMAN47128PCV Rubber Hose Connectors
FELPRO45458Timing Cover Gasket Set with Repair Sleeve
FELPROVS50458RValve Cover Gasket
FELPROBS40183Rear Main Seal
FELPROOS34308ROil Pan Gasket
Mopar68218058ACATF+4 Transmission Fluid
MELLINGM167HVSHigh Volume Oil Pump and ScreenOrder # 144016717
DORMAN47079PCV Elbow (Back of Valve Cover)Order # 144016717
DORMAN47057PCV Elbow (Front of Valve Cover)Order # 144016717
TIMINGPurchased, but didn't install
CLOYES90385SATiming SetNot Installed
CLOYESC385[Kit Component] Timing ChainNot Installed
CLOYESS809[Kit Component] Timing Crank SprocketNot Installed
CLOYES95337 (9-5337)[Kit Component] Timing DamperNot Installed
CLOYESS822T[Kit Component] Timing Cam SprocketNot Installed
SKPSK594018Harmonic BalancerNot Installed
ELECTRICAL
MOPAR56021441ACUnderhood Light
MOPAR5019411ADThrottle Position SensorNot Installed
MOPAR4727451AACrankshaft Position SensorNot Installed
BRITTARAIL-06BW12Courtesy Lamp 6" (X2)https://wranglertjforum.com/threads/it-just-happened.55698/post-1384506
QUIORANGE5810Round 2.39" Third Brake Light (Spare Tire Carrier)
HYDLIGHTk1lt0112" LED Strip Lights
OURBEST8542082485H4 9003 LED Headlight/Fog Light Harness
GRANDVIEW10P-T5-0022GZ-RRed T4.2 COB 1 SMD Led
GIVEUBEDT10-5smd-12pcs-Ice BlueT10 194 LED Car Bulbs,192 LED Car Bulbs,168 LED Lights Bulb, 5smd Ice Blue
MAOXINDODOFUN-T5T5 37 74 LED Bulb with Twist Lock Socket PC74 PC37 Blue
BLACK MAGIC BRAKESLED TAIL LIGHTS WITH DUAL INTENSITY SIDE LIGHTS - BLACK HOUSINGNot Installed
FRONT AXLE
MOPAR34201535.6Hub Bearing Bolts
TIMKEN‎HA597449Axle Bearing and Hub Assembly (2)
SUPERIOR4340 Dana 44 Axle ShaftsPurchased NIB from Club NOVA Memberhttps://wranglertjforum.com/threads/it-just-happened.55698/post-1432246
TJ PERFORMANCEBP-DT044DANA 44 DIFF COVER BP-DT044BARNETThttps://wranglertjforum.com/threads/it-just-happened.55698/post-1451611
REAR AXLE
MOPAR4137696ABAxle Housing Vent (For Brake Line)
BRAKES
CENTRIC15067352 (150.67352)Brake Hose
CENTRIC15067353 (150.67353)Brake Hose
RAYBESTOSFRC11268NCaliper
RAYBESTOSFRC11267NCaliper
RAYBESTOSFRC10185NCaliper
RAYBESTOSFRC10186NCaliper
RAYBESTOSBH380889Brake Hose
SKPSKY01034Brake Backing Plate / Dust Shield
STEERING AND SUSPENSION
ROCKJOCKCE9133FFront 3" Springs
ROCKJOCKCE9131RH1PRear 3" Spring
SKYJACKERB8556CSBlackmax Front Shocks9.78" Travel (5.5" Up and 4.28 Down, with 2" Bump Stop
SKYJACKERB8518CSBlackmax Rear Shocks9" Travel 4.5 Up and Down, with 2" Bump Stop
STREETRAYS274430651624Leveling Coil Spring Spacer
SAVVYTJ/LJ JOHNNY JOINT® ALUMINUM CONTROL ARM SET - 8 PIECES
ROCKJOCKCE-9701Currectlync Steering System
ROCKJOCKCE-9120TJSJohnny Joint Front Trac BarNot Installed
ROCKJOCKCE-9121NGeometry Correction Axle Bracket for RearNot Installed
ROCKJOCKCE-9120RSJohnny Joint Rear Trac BarNot Installed
BLACK MAGIC BRAKES4340 TIE ROD HEAT TREATED WITH HEAVY-DUTY TIE ROD CLAMPS
OROSwaylochttps://wranglertjforum.com/threads/it-just-happened.55698/post-1392079
BODY AND ARMOR
NEXT VENTURENV-00386TJ/LJ Ultra High Clearance Rear Bumper × 1 Bare Metal / Include Frame Tie In Kithttps://wranglertjforum.com/threads/it-just-happened.55698/post-1418593
SAVVYSAV-TJFFront BumperWith hooks, fairlead mount, light tabs, and winch guardhttps://wranglertjforum.com/threads/it-just-happened.55698/post-1416010
SAVVYUAM-LATEUnder Armor Belly and Engine SkidNot Installed
SAVVYSAV-TGLAluminum Tailgate Skin for 03-06 No VentNot Installed
SAVVYSAV-VLNCSAV-VLNC - Aluminum Tailgate Valance 97-06Not Installed
SAVVYSAV-BLTJAluminum Body Lift 1.25" TJ/LJ 97-06https://wranglertjforum.com/threads/it-just-happened.55698/post-1446094
SAVVYSAV-TJSSSteering Box Protection - Aluminum TJ/LJ 97-06https://wranglertjforum.com/threads/it-just-happened.55698/post-1416313
SAVVYSAV-RKRLJSavvy LJ Rockers w/ Step SlidersNot Installed
SAVVYSAV-GTSSAV-GTS Aluminum Savvy Gas Tank Skid 1997-2006 TJ/LJNot Installed
GENRIGHTCNR-6012LJ Corner Guard Set (Standard) - Aluminum
GENRIGHTTFF2710-PTJ/LJ 4" Flare Front+Rear Fender Package - Aluminum, with inner fenders
WHEELS AND TIRES
MOPARMopar 392 Beadlocks with 315/70R17 BF Goodrich KO2s (C Rated)https://wranglertjforum.com/threads/it-just-happened.55698/post-1423060
FASTFREE5x4.5-5x5-1.25H-71.5-1/2B-1015x4.5 to 5x5 Wheel Adapters 4PCS for Je-ep Jk Wk Wj Xk Wheels on Tj Yj Kk Xj Mj Kj Zj, Dynofit 5x114.3mm to 5x127mm 1.25" Forged Conversion Wheel Adapters 1/2" Thread
FASTFREE101bk-1pc5x4.5 to 5x5 Wheel Adapters for Je/ep Spare Tire Jk Wk Wj Xk Wheels on Tj Yj Kk Xj Mj Kj Zj, Dynofit 5x114.3mm to 5x127mm 1.25" Forged Conversion Wheel Spacers 1/2" Thread Adapter
