If you have any last minute things to button up, head up here with Alex on the 16th and we'll knock em out.
Well, there is only so many hours in a day, lol! What brakes are you getting? BBK? or just BMB pads and rotors?
HahaI have the super 16. I’ll probably get it installed locally. Maybe I can use you to help with the angles and doing bump stop though on the 16th if you think we’ll have time
I can knock out the brakes so take that off the list. It's the 16" BBK. Tom needs help with angles and bumps. The rear bumps will probably be the same since shocks will be the limiting factor and I would bet the front needs around 2-2.5". My eyeballs tell me the rear needs the uppers lengthened a bit but on the front I'm lost since I'm not sure how to properly measure castor.Well, there is only so many hours in a day, lol! What brakes are you getting? BBK? or just BMB pads and rotors?
I can knock out the brakes so take that off the list. It's the 16" BBK. Tom needs help with angles and bumps. The rear bumps will probably be the same since shocks will be the limiting factor and I would bet the front needs around 2-2.5. My eyeballs tell me the rear needs the uppers lengthened a bit but on the front I'm lost since I'm not sure how to properly measure castor.
Sounds like a Jeep Party on the 16th....I'll be there.If you have any last minute things to button up, head up here with Alex on the 16th and we'll knock em out.
Pinion angle will be the determining factor and caster will be where it will be provided no ds vibes up front. Refresh my memory, are you installing Savvy's TT on his rig? You'll have to get the pinion angles vibe free before he can drive all the way up here. We can put an angle finder on the top ball joint and get a relative idea where caster is. Has the front lower spring perch been drilled/tapped yet for bumps? We can do washers and longer bolts for the rear upper bumps, or drill/tap the lower perch.
@tomtaylz correct me if I'm wrong but I believe we installed 2" bumps extensions in the F/R.Pinion angle will be the determining factor and caster will be where it will be provided no ds vibes up front. Refresh my memory, are you installing Savvy's TT on his rig? You'll have to get the pinion angles vibe free before he can drive all the way up here. We can put an angle finder on the top ball joint and get a relative idea where caster is. Has the front lower spring perch been drilled/tapped yet for bumps? We can do washers and longer bolts for the rear upper bumps, or drill/tap the lower perch.
Wow thanks for the photo. should be quite easy to accomplish that.
@bobthetj03 any tips on adjusting the currie upper control arms besides a pipe wrench? I don't think tom wants his PC getting all messed up.
That's one good looking jeep. The black one in the garage isn't too bad either.Not the best pictures, I was a bit space constrained but rockers back from the powdercoater and installed and painted flares are back on
Took her for a test drive, a lot of noise I think there’s still some contact from the transfer case from the tummy tuck, so Uber to get home hah.
View attachment 79718View attachment 79719
