I'll answer for Tom since his is still working on his jeep. Yes the measurement was taken after tt.Did you measure for the rear ds after you installed the TT?
What did it do with the rear drive shaft in and no spare tire on?
Whoops, probably not clear there in my post. With the rear driveshaft on and no spare was the ~70% reduction in vibes.
On the very short drive with no rear drive shaft (4H) and spare on there was no noticeable vibes
Have not tried no spare and no rear driveshaft.
Does your Jeep set level or a little lower in the rear?
How much do you think that spare weighs? So, let me get this straight, you took the spare off and 70% of the vibes above 60 mph went away?
On level ground, put your angle finder on the flat step portion of your slider toward the rear of the slider and note angle. Then, put the spare tire back on and note the angle change. What is the change?
Im dumbfounded. You do have the spare 35 in the trunk though so its not like all the weight is gone. Maybe take that out?
If I had to guess, I would assume it was only 70% reduction as maybe I still need to dial in he angles for my Jeep, not sure about the idle vibes though, those were there driveshaft or not, ensured there was contact on the passenger MML.
I’m guessing the weight from the spare won’t change driveline angles? That seems silly
Just the difference in a full tank of fuel vs. 1/4 tank makes a small difference.
I think more experimentation is needed. Placement of the spare can change how the jeep sits. You hang 70lbs. of spare behind the bumper vs. laying it in the tub behind the seat will be different. My suggestion, mount the spare on the exogate, fill the tank full of fuel, then take an angle measurement of the rear ds. Drive thru a the tank of fuel till 1/4 tank, then remove the spare all together, then re-measure ds angle.
